Turns on or off external Python scripting support when FIPS mode is turned off.
| on | Turns on external Python scripting support (default). |
| off | Turns off external Python scripting support. |
By default, when FIPS mode is off, external Python scripting support is enabled.
To enable external Python scripting support with the command, FIPS mode must be turned off (configure security fips-mode [on | off]). Python scripting configuration is ignored when FIPS mode is turned on.
The following example turns off external Python scripting support:
# configure security python off
This command was first available in ExtremeXOS 33.1.1.
